https://linustechtips.com/topic/279918-k70-rgb-help/#findComment-3800358
Double post is double.
Contact COrsair or something
https://linustechtips.com/topic/279918-k70-rgb-help/#findComment-3800405
Contact corsair. If it came with a broken key they will replace it. If you broke it then it is your fault, corsair will say.
If it wasnt you contact corsair. if it was you, be creative and think for solutions:D that is what I would do
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/279918-k70-rgb-help/#findComment-3800435
