Hey guys,
I have a reference gtx 780ti, and I am planing to go with a second one soon.
My question is:
Can you SLI same graphics cards but with different pcb?
For example: reference gtx 780ti  +  gtx 780ti classefied edition
or
                      reference 780ti  +  gainward gtx 780ti phantom
Thx
So long as you have the same GPU configuration you should be fine. Two GK110's with 2,880 CUDA cores.
If one card is faster it will be clocked down to match the slowest card.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
Yes. You can put those two cards in SLI. The things to look for when looking for SLI compatibility are these: Same chipset, same amount of VRAM, and same bus width.
That might be true out of the box, but I've had two 660 Ti's run at differing clocks when I overclocked them.
Really? Interesting.
Yup. I couldn't get them to even out unless I reset them. Once I overclocked them, one would start hitting higher values than the other.
