hi all i have a 7870 and it needs two 6 pin cables ...
i know i plugged both in but my mind keeps telling me i only plugged one in >.>
and i can not open the case again .. not that im lazy its a very big hassle as i need to move the big table and all the stuff out of the way Y_Y
is there a way to check it without opening the case ?
CPU: Fx 8350 | CPU Cooler: Coolermaster Hyper 212 Evo Now  AMD STOCK CPU COOLER | Motherboard: Gigabyte GA-970A-DS3 (rev 1.1)   NOW MSI 990FXA-GD80 | Ram: Corsair Vengence 8GB DDR3 Motherboard detects 7gb for some weird reason | Graphics Card: SAPPHIRE HD 7870 GHz Edition 2GB GDDR5 |  HDD: 1 TB samsung
Case: CM elite 310 | Monitor: Aoc e2050S
OS: Windows 8 Professional 64 Bit NOW  Wndows 10 Professional 64 Bit
 Power Supply: Cooler Master Thunder 500W NOW GX 650W v2
https://linustechtips.com/topic/279018-how-to-check-gpu-power/
It wouldn't display if they aren't plugged in.
https://linustechtips.com/topic/279018-how-to-check-gpu-power/#findComment-3784274
Turn it on. If it doesn't then open the case.
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/279018-how-to-check-gpu-power/#findComment-3784390
