will i have enough room to overclock my evga gtx 750 ti ftw edition? im only wanting to overclock the card nothing else until i can get the money to get a new psu and the gtx 970.
My Build Specs.
Cpu - I5 3570k stock clock
Gpu - EVGA gtx 750 ti ftw Edition
Ram - Corsair Vengence 2x8gb 1600mhz cas 9
Mobo - Msi h61m-e33/w8
Psu - Corsair CX430
https://linustechtips.com/topic/278530-overclocking-help/
sure, just go for it!
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/278530-overclocking-help/#findComment-3775463
wait what do you mean by that? ive never overclocked anything before.
every part of silicon is different, even within the same model name. so to find out wheter yours does overclock, you need to try it. ;)
https://linustechtips.com/topic/278530-overclocking-help/#findComment-3775644
so i should be able to overclock it with a 430 watt psu?
oh yeah, thats what you meant. 400W is probably enough for any gpu on the market right now.
https://linustechtips.com/topic/278530-overclocking-help/#findComment-3775899
