I'm building a PC for the first time and I've found some of the most important parts such as, CPU, Motherboard, Graphics card and PSU. There's still a few other things to look up, but right now I need some help understanding cooling, what are the sort of things that I need to think about when deciding which cooler to get? I have made a decision that I want the cooler to be fan powered for now and possibly upgrade it to water at a later date.
https://linustechtips.com/topic/278412-help/
Main factors are noise level, cooling power, and depending on your case, size.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/278412-help/#findComment-3774161
Yup. Statik has basically said it. If you want a quiet pc, how good it actually is at cooling and most importantly if it will actually fit in your case. Also make sure it supports your CPU.
ALCATRAZ |   CPU: i9 9900k @ 5GHz, Motherboard: Asus Prime Z390-A, RAM: Corsair Vengence LPX 32GB, GPU: Gigabyte 1070Ti Case: Zalman MS800 Plus, Storage: Corsair 2TB NVME | Crucial M550 128GB SSD  |  WD 640GB HDD, PSU: XFX Pro Series 1050w, Display: ASUS MG279Q, Cooling: Noctua NH-D15
https://linustechtips.com/topic/278412-help/#findComment-3774186
I would like to add that you should choose cooling hardware that suits the rest of your hardware => A more powerful CPU should be fitted with a more powerful cooler.
Depending on the type of your GPU cooler you should scale the cooling performance of your case fans. For example, Windforce coolers push hot air into the case while the stock cooler sucks air out of the case.
Regards,
Lorunification
Machines take me by surprise with great frequency
https://linustechtips.com/topic/278412-help/#findComment-3774222
Most deciding factors in choosing air cooling are your case limits, sometimes your RAM limits and your budget. After that comes your style "limit". You can get good, well performing cooler in $30 212 EVO or spend over $70 to markets finest in Noctuas D14 and D15. There is noticable difference when you move up tiers. But the main thing is that you can get decent OC with just EVO. It will keep your CPU cool and rather quiet if that is what you are looking for. With more money comes more in everything.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/278412-help/#findComment-3809509
