New build, will not power back on
I put a jumper on the power supply for the green and black wire. The fan on the power supply does not kick on anymore.????
Weird. I had bought a corsair GS800 power supply and it only lasted me less than a year and it would spike and randomly turn off. I dont trust them anymore. I switched to an NZXT power supply.
Try this:
The machine doesn't do anything. No beeps, LEDs or spinning fans.
- Check if your power cable is firmly plugged in on both ends (you would be surprised how many issues this resolves)
- Check if the power supply (PSU) has a button to cut the power to the machine. Check if this button is in the position denoted with ON or I
- Check if EVERY power cable is plugged in securely, reseat if necessary.
- Check if the power button is installed correctly (consult your motherboard manual)
- Try shorting out the pins you connect the power button to manually. If this powers on your system, you have a faulty power button.
- Check with a device of which you know that it works if the power outlet you're using is actually providing power.
If this hasn't solved the problem, check if your PSU isn't dead. To do this, you can follow these steps:
- Unplug your power cord and/or flip the switch on the back of the PSU in the position denoted with OFF or 0
- Unplug every connector coming from your PSU (this is very important)
- Using a bent paperclip, short out the green wire on the 24 pin header with any of the black wires, like so.
- If you have a PSU that shuts down its fan under low load, or a PSU that is fanless, connect something small like a hard drive to it.
- Plug in your power cord and/or flip the switch on the back of the PSU in the position denoted with ON or I
If the PSU does NOT power on (the fan/hard drive you connected should start spinning) after following these steps, your PSU is in all likelyhood defective. Request an RMA.
If the PSU DOES power on, then the problem is most likely your motherboard.
I got that quote from : http://linustechtips.com/main/topic/42440-readme-how-to-respond-to-a-no-post-or-no-power-up-situation/
Good luck I know how frustrating this is! Especially on Christmas and trying to get your son involved on this. Hopefully we get this solved.
