no, just try to get the same model or brand if possible, for better chance of compatibility.
the timings and frequency will run at the lowest of all your DIMMs so if you buy higher speed ram it will work fine but just slower.
https://linustechtips.com/topic/276740-help-with-a-ram/#findComment-3756638
The only thing a I usually look out for is voltage, since most motherboards don't control the voltage per DIMM, but per channel. Brand, frequency and all of that stuff, doesn't matter that much.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/276740-help-with-a-ram/#findComment-3756648
Try to get same speed. If possible get same brand and model too!
If you buy a higher clock than the one you have, It'll run only at the speed of Older one!
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/276740-help-with-a-ram/#findComment-3756720
