My brother's comp is experiencing a problem! It suddenly turned off and now no matter how many times we turn it on it just auto shuts off after a second without displaying anything!
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/276218-help/
any beep codes or flashing lights?
also whats the specs
No beep!
some i5 cpu
no sure about MOBO
MSI 460 twin frozr
some generic PSU (im trying to plug my g600w in right now to see whether if it is the PSU)
https://linustechtips.com/topic/276218-help/#findComment-3750133
the mobo is MSI h67MA-E45
https://linustechtips.com/topic/276218-help/#findComment-3750153
I had a similar problem recently, it was the cmos battery, i took it out for about 15 minutes, then put it back in and everything worked. You could also try and make sure the power and reset switches aren't lose. I'd recommend doing the latter first.
https://linustechtips.com/topic/276218-help/#findComment-3750155
are you able to get to bios or does it shut off first
it doesnt display anything on the monitor!
what is a cmos battery D:
https://linustechtips.com/topic/276218-help/#findComment-3750158
Okay basically when i turn on the machine is starts up for like 2 seconds then it shuts down. After that it starts up again and the cycle repeats (even after i have changed PSU)
https://linustechtips.com/topic/276218-help/#findComment-3750176
does the pc do something similar to this?
EDIT: @xnoobftw i don't know then, sorry..
https://linustechtips.com/topic/276218-help/#findComment-3750185
Nope! it does the cycle as mentioned above only when i on it
https://linustechtips.com/topic/276218-help/#findComment-3750194
Please,go read your mobo manual to see how to reset CMOS
the shiny coin looking thing on the motherboard
Looks like clearing cmos did the trick! My brother and i humbly thank you guys for the assistance :)
https://linustechtips.com/topic/276218-help/#findComment-3750301
It could be your psu fan isnt working or the fan isnt working... the main killer of psu is dog hair
https://linustechtips.com/topic/276218-help/#findComment-3753398
Oh well. Atleast I think you read the manual c:
Yeap i did :) Thanks!
I fixed it through CMOS reset :) Thanks for the help anyways!
https://linustechtips.com/topic/276218-help/#findComment-3754237
