HELP Overclocking Core 2 Duo E8400
Go to solution Solved by flibberdipper,
So is it still possible you guys can give me a thread or a tutorial anyway for the core 2 duo? I mean its just im experimenting on it and want to be confident enough so that I can do it without hesitation on my i5.
This should do it for you.
PS: When you want to respond to someone, use the "Quote" button in the lower right of their post so that they know you replied. ;)
Can I get some help, tutorial, and suggestion to overclocking? Specifically my old Core 2 Duo E8400.
Im kind of new to overclocking and wanted to do it first on this old chip so that I could do it after wards on my i5 3570k.
I was aiming maybe at 4.0Ghz with an after market heat sink. If you can get me video tutorials or thread tutorials that would be much appreciated.
PC Specs:
Motherboard: Asus P5G41T-M LX PLUS
CPU: Intel Core 2 Duo E8400
Cooler: Cooler Master Hyper 212 PLUS
GPU: EVGA GTX 550 Ti
RAM: Patriot Viper Xtreme 8GB Single Module (1600mhz)
PSU: Antec VP450 450W Continous Power
CASE: Some Azza Case
https://linustechtips.com/topic/276210-help-overclocking-core-2-duo-e8400/
Overclocking on 775 CPUs is different with 1156/1155/1150 CPUs.
On the old 775s, you need to dial up the FSB. This in turn overclocks your CPU, ram and the FSB itself.
On the newer CPUs, you generally only need to turn up the multiplier (on K-series unlocked CPUs) to overclock. You may also use the BLK to overclock which also affects your ram.
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
Honestly, overclocking on K-SKUs now is so much easier than 775 and the early Core ix chips. Just up the multiplier and you're golden (after a stress test with AIDA64, of course).
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
Main rig on profile
VAULT - File Server
OptiPlex 7040M
PC Specs:
Have a look at this: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/#entry3175763
It's a great overclocking guide, written by @harrynowl. Used it when overclocking my Q8200.
LTT's unofficial Windows activation expert.
Like this?  :P  Thanks! Sorry for being such a noob.
Yup. :)
Main rig on profile
VAULT - File Server
OptiPlex 7040M
