Any Haswell i5 will suit you well, the best i5 being the i5-4690K which is overclock-able.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
5960x
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
5960x
The 5930k would perform better than that and cost $500 less.
OT: get a 4690k, or if you need to spend less, whatever is the cheapest i5 at the time.
To be honest both would be throwing money out the window. A i5-4690k alone at stock will push a GTX 970 to it's performance wall.
I know, I was saying that a 5960x is worthless for gaming, no matter what else you have because the 5930k is better and cheaper. The 5820k is a decent value if you have sli 980s or higher or also want to do some video editing or other productivity.
Pentium 4 HT
i7 5930k . 16GB Corsair Vengeance LPX 2666 DDR4 . Gigabyte GA-X99-Gaming G1-WIFI . Zotac GeForce GTX 980 AMP! 4GB SLi . Crucial M550 1TB SSD . LG BD . Fractal Design Define R2 Black Pearl . SuperFlower Leadex Gold 750w . BenQ GW2765HT 2560x1440 . CM Storm QF TK MX Blue . SteelSeries Rival
i5 2500k/ EVGA Z68SLi/ FX 8320/ Phenom II B55 x4/ MSI 790FX-GD70/ G.skill Ripjaws X 1600 8GB kit/ Geil Black Dragon 1600 4GB kit/ Sapphire Ref R9 290/ XFX DD GHOST 7770
5930K is not better at all.
Haswell i5 is the best choice for gaming, with 1 or 2 video card
The 5820K with 28lanes will give the same amount of performance as the 5930K in gaming with 1 or 2 or 3 card in SLI/Crossfire / 3ways Solution. The difference in performance between 8X GEN3 and 16X GEN3 are very small, not worth to speak about that on current generation of video card.
The 5930K with 40lanes will be a + if you have multiple video card + PCI-Express stuff like SSD or Raid card, or if you want to do 4ways configuration with benchmark / 4K performance etc
And the 5960X is only the choice for productivity, otherwise it's a waste of money and might not overclock as far as the 5820K/5930K, less clock speed could equal to less performance in most games.
The i5-4690K is the definite answer. Almost no need to discuss that.
Great price to performance, gaming performance identical/comparable to the high-end HT-processors.
Spending more money won't net you anything in return. You'll litterally be spending money on something you won't be able to take advantage of.
CPU: Core i7-4790K
GPU: 2x MSi GTX 970 GAMING G4
MB:   ASUS Z97-AR
