LED quiet fans
Go to solution Solved by theloveablemoose,
I'm looking for some quiet LED fans just link it below if there is a thread for this already just link that took thanks.
looking for red or blue LEDs.
$20 to $30 for price range.
Friend recently bought the Bitfenix Spectre pros the blue LED version and from what i could tell they were fairly quiet.
https://linustechtips.com/topic/275621-led-quiet-fans/#findComment-3742557
^ Dis, they are good
Linky: http://www.amazon.com/BitFenix-BFF-LPRO-14025R-RP-Spectre-140mm-Case/dp/B007OWPV6U/ref=sr_1_5?ie=UTF8&qid=1419355756&sr=8-5&keywords=bitfenix+spectre+pro+140mm
https://linustechtips.com/topic/275621-led-quiet-fans/#findComment-3742573
Would prefer to recommend some Be Quiet! Silent Wings 2's or mid-speed Shadow Wings, or maybe some Akasa Apache/Rosewill Hyperborea's along with some LED strips. It tends to be a better idea.
But Cougar has some LED fans, if they're anything like their non-LED fans then they should be decently quiet.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/275621-led-quiet-fans/#findComment-3742574
