Hi guys , i hope you are fine
I'm here to talk with you about a problem i have with my computer
I just bought a new build , the case is the cooler master storm enforcer , the motherboard asus b85 pro gamer and it's running on windows 8.1
When i plug a usb 3.0 device on the front panel it can't read it , but when i plug a usb2 device in the same port it works fine , the usb3 device i'm trying to plug is an external hdd that works fine at the back panel of the motherboard
I don't know if it's a hardware or a software problem , because in my bios when i set the usb ports to ehci everything works fine but i lose the usb 3 speeds , the ports work as usb 2 ones
I'm sorry for my bad english , and i thank you all who took the time to read my topic
It's very disappointing since all the hardware is new , i can try to return the case but i don't know if it's the case problem or the motherboard one , and i won't be able to use my computer that time
https://linustechtips.com/topic/275515-front-panel-usb3-work-only-on-usb2/
Download drivers from here
Case: Xigmatek Alfar (Black) | CPU: Intel Core i5 4460 @3.2GHz | MoBo: Gigabyte GA-Z87-D3HP | RAM: Crucial Ballistix Sport 8GB 1600MHz | GFX: Gigabyte GTX 660Ti 2GB
Cooler: beQuiet! Shadow Rock | SSD: Samsung 840 EVO 120GB | HDD: Seagate 'Barracuda' 2TB| OS: Windows 8.1 PRO (64-bit) | PSU: Zalman ZM600-GT 600W 80+ Bronze
 Screen: ASUS VS228 | Mouse: Razer Naga Molten | Headphones: Qpad QH-85 | Keyboard: Razer Blackwidow 2013 w/ Cherry MX Blue
see if you have a USB 3.0 Thumb drive to verify
also look inside you case and make sure the usb 3.0 header is fully in
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
hi guys , thank you for replying
The usb3 header is fully in , and the powersaving feature is disabled
I think i'm gonna ask for a case replacement
Do you think there are chances that it would be my motherboard who is the problem ?
yea could be either the mobo or the case
External hard drives and dvd burners are generally meant for the back i/o panel. Not front. That could be your problem. Try connecting another USB 3.0 device to the header
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
not quite true
I can plug the external drives with no power loss for my movies
