depends on #siliconlottery
you can never expect a good overclock, you can only pray, just like when you open a csgo case, pray...
I'd say the G1, it has a better cooling solution, but it really just depends on your luck.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
970 for 4k?
You should be using single monitor, right?
G1 is betta!
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
The G1 is a safe bet but consider the Strix, many are starting to pop up on forums as being just as competitive if not more, the Strix has a damn good build quality.
Goldeneye [in Progress]
i4770k @ 4.5GHz | Asus Maximus VII Hero | GSkill Trident X @ 2400MHz | Asus 970 Strix @ 1573/2073Mhz
