I was thinking about doing a PC build for my little brother he only plays minecraft and watches youtube and plays some online flash games, I was think of a build that would suffice but would not be over the top, I was no going to build it any time soon I was just wanted some recommendations.
Case: Corsair 200r
PSU: Corsair CS550M
CPU: A8-6600k
RAM: 2x 4GB Kingston HyperX Fury 1600mhz
SSD: Samsung 850 Pro 256GB
GPU: Sapphire 270x 2GB Dual-X
Motherboard: Gigabyte ga-f2a88x-d3h
Optical Drive: LiteOn iHAS124
The main thing I am wonder is will this run minecraft well at full
Main PC: CPU: i7-4770k RAM: 16GB Kingston HyperX Blu SSD: Samsung 850 Pro 256GB HDD: 1TB WD Blue GPU: ASUS GeForce GTX 770 2GB PSU: Corsair CX600M Case: Bitfenix Shinobi OS: Windows 10 Pro 64-Bit
Laptop: ASUS N56VJ
https://linustechtips.com/topic/274035-pc-build-for-brother/
Budget? The 850 Pro is more expensive than something like an MX100 would be, and you can get an FM2 CPU and not an APU. That'll save some money too.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/274035-pc-build-for-brother/#findComment-3721646
I was thinking about doing a PC build for my little brother he only plays minecraft and watches youtube and plays some online flash games, I was think of a build that would suffice but would not be over the top, I was no goign to build it any time soon I was just wanted some recommendations.
Case: Corsair 200r
PSU: Corsair CS550M
CPU: A8-6600k
My Minecraft runs at maxed out everything, 1080p with a GTX980 and i7-4790k hitting about 150fps-ish in online games.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/274035-pc-build-for-brother/#findComment-3721666
You could probably get away with a pentium g3258 if thats any cheaper, and I'd go for the samsung 840 evo as its a bit cheaper of an ssd but still pretty good.
https://linustechtips.com/topic/274035-pc-build-for-brother/#findComment-3721697
You don't need an 850 pro for this system, use a cheaper SSD such as the Crucial MX100 or 840 EVO and move the money to a better CPU.
Do not combine an APU with a graphics card, rather buy a better CPU as the graphics part of an APU will not be in use when running the 270x.
https://linustechtips.com/topic/274035-pc-build-for-brother/#findComment-3721711
Ok I will change the SSD to an 840 Evo 256GB SSD instead, I will probably stick with the 6600k though as I would only getting what he needs, I know the built in GPU will be redundant though
Laptop: ASUS N56VJ
https://linustechtips.com/topic/274035-pc-build-for-brother/#findComment-3721893
