How Bad is LED?
Go to solution Solved by othertomperson,
All display are LED, LCD. LCD creates the image, LED is the backlight. TN isn't great though. Get an IPS instead.
Anyone who comes to a thread about monitors and recommends a 144hz G-Sync IPS panel immediately outs themselves as not knowing what they're talking about.
Ignore people insisting that you buy products that don't exist. Cheap TN monitors are horrendous and awful. Good ones are good. A TN G-sync monitor will give you as smooth a gaming experience as money can buy right now, so enjoy it. The colour accuracy is not 100%, but it's damned close. It's only worth considering if you're in professional content creation where you need an absolutely accurate monitor to ensure uniformity of your creations. I'd also recommend it for surround/eyefinity where slight differences between them become very noticeable. Horizontal viewing angles are generally fine. Vertical not so much, so if you're mounting this on a wall above you, or looking down on it from another storey then IPS would serve you better. But honestly who the hell does that with a PC monitor?
Found this G-SYNC monitor by AOC which is looks great but is LED.
http://www.scan.co.uk/products/24-aoc-g2460pg-144-hz-g-sync-gaming-display-displayport-1920x1080-350cdm2-80m1-1ms-usb-hub
For the price it looks great to my amateur-eye.
Any reason as to why it might not be good?
https://linustechtips.com/topic/273153-how-bad-is-led/
All monitors are LED.
It's TN it's bad, get xl2420g if you want g-sync.
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3708068
All 144hz monitors are TN, and I wouldn't call TN bad. My BenQ XL2411Z is pretty good -- not as good as my Dell P2414H, but certainly not bad.
Asus VG248QE and BenQ XL2411Z are better options (if they're not significantly more expensive).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3708079
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3708084
Yeah, and TN have the best response times, it's just that the viewing angels are bad and colours not perfect, but not bad either.
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3708117
Problem with that is that its another 200 pounds more.
You will be just fine with a TN. Pretty sure that is what I have on my laptop and the colours are ok. Everyone told me to get a IPS monitor and I got an MVA and I love it. Types of panel only matter if you go dual monitor and you need good viewing angles.
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3708128
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3708141
Ignore people insisting that you buy products that don't exist. Cheap TN monitors are horrendous and awful. Good ones are good. A TN G-sync monitor will give you as smooth a gaming experience as money can buy right now, so enjoy it. The colour accuracy is not 100%, but it's damned close. It's only worth considering if you're in professional content creation where you need an absolutely accurate monitor to ensure uniformity of your creations. Horizontal viewing angles are generally fine. Vertical not so much, so if you're mounting this on a wall above you, or looking down on it from another storey then IPS would serve you better. But honestly who the hell does that with a PC monitor?
I never said get 144Hz IPS. They don't exist. I myself would prefer 60Hz, IPS over 144Hz TN. Just my opinion.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3708155
Actually, LCD does not mean it is LED.
It needs to specifically state "LED" for it to be LED, otherwise the monitor uses something called CCFL, which uses glass tubes filled with gas to produce light. These are thicker than LED monitors and are an older technology, from before LED was introduced.
All LED monitors use LCD, but not all LCD displays use LED backlighting. :)
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3708157
It needs to specifically state "LED" for it to be LED, otherwise the monitor uses something called fluorescent backlighting, which uses glass tubes filled with gas to produce light. These are thicker than LED monitors and are an older technology, from before LED was introduced.
Thanks for the correction.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3708167
OK, then don't pretend you are even attempting to match the specifications of the OP's example. And don't pretend that your personal preference is anything but that.
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3708179
Monitors are a matter of preference. I was giving my opinion. No need to be an asshole about it.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3708779
I'm not being the arsehole here. OP asked for consumer advice in choosing a monitor. You completely ignored the specs they were looking at, expressed your own opinion and preferences as undeniable fact and did it in a deliberately misleading way.
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3708884
I answered his question. He wanted to know if LED monitors were bad. After that I gave him my opinion, on  what kind of monitors I personally like. That's it, I didn't mislead at all.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3709032
This is what I take issue with. OP made it clear that they were interested in G-Sync, they made it implicit that they wanted high refresh rate. Your advice was unhelpful.
Sorry, I worded it incorrectly. I should've said I prefer IPS. Apologies.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3709074
"How bad is the topic title" is the question ? ;)
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/273153-how-bad-is-led/#findComment-3712097
