I just got my G1 970, and I want to benchmark it vs my 290x Lightning to see which is better, can someone help me out I have a few questions.
Where in these games should I compare the cards and for how long?  (Like which scenes, which parts of the game, etc?) Should I just use fraps to record the average FPS over that time-frame?
I have the following games:
Titanfall
BF4
BF3
The Crew
FC4
FC3
Call of Duty AW
Crysis 3
Bioshock Infinite
Dirt 3
Witcher 2
Tomb Raider
(I have a lot more games, but those seem to be the popular ones to benchmark)
All the testing will be at 1440p, I'm going to OC the cards as far as I can on air, and write down their overclocks etc.
https://linustechtips.com/topic/272872-benchmarking-help/
I think FRAPS and some monitoring software, like Afterburner can help. But it wouldn't hurt to try one synthetic benchmark once in a while.
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3701843
The problem is some synthetic benchmarks seem to like certain things more, IE: a 290x may score lower in things like Unigine for having slower VRAM, but in games they will perform the same etc.
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3701863
Well try valley, it will give you a score. Run it 5 times and record it each.
Then do the lightning exact same settings and bench 5 times.
Why 5? Because sometimes GPU's get angry at us users and don't perform as we'll.
Valley benchmark
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3701864
Maybe it's just the program. Try something like FurMark or 3DMax.
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3701866
Uniting is a game, well a game map running through scenes, it simulates a little harder then bf4. Don't get the score then, record fps
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3701874
Titanfall
BF4
BF3
The Crew
FC4
FC3
Call of Duty AW
Crysis 3
Bioshock Infinite
Dirt 3
Witcher 2
Tomb Raider
as far as I know
Bioshock Infinite - built in benchmark
Dirt 3  - built in benchmark
Tomb Raider  - built in benchmark
You could use FRAPS for the rest, maybe MSI AfterBurner can log the FPS to a file?
The hard part is not choosing which part of the game, but making each run consistant... I am very interested in your results however :-)
Sim Rig:  Valve Index - Acer XV273KP - 5950x - GTX 2080ti - B550 Master - 32 GB ddr4 @ 3800c14 - DG-85 - HX1200 - 360mm AIO
Quote
Long Live VR. Pancake gaming is dead.
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3701916
Dont forget Metro and Grid AutoSport
Metro is as punishing as Crysis
Grid AutoSport is all about the highest fps
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3702009
I don't have metro, but I have grid autosport
I'll do all that stuff for sure.
Should I just make a google spreadsheet for the results?
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3702023
google docs or normal excel sheet uploaded into google drive
yea good luck with the data collection :)
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3702037
970 appears to be a tiny bit slower, but it literally makes NO NOISE at all.
I ran unigine for 15 mins, max temp 64c at minimum fan speed 1418 mhz without touching the core clock at all.
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3702864
my 980 is about 20% slower than my old crossfire r9 290's and about seven-thousand times quieter...
oh and wont have to format your PC when you update drivers with Nvidia cards!
Quote
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3705583
Hitman absolution
Arkham city + Origins
Just Cause 2
Sleeping Dogs
Dirt 3 + showdown
F1 20**
All have built in benchmarks, try some of these if you have them
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3706031
Don't forget that Unigine Valley isn't a good choice in terms of benchmarking a GM204 chip. If you want more accurate benchmark results use Unigine Heaven and 3D Mark FireStrike.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3706940
These are my results so far
https://docs.google.com/spreadsheets/d/1bZI8G3YIwAXkiKBvbaNE-mic2Pnoab_85pslbiIYP4w/edit#gid=0
Lightning was at 1175/1550, G1 was at 1582/7750
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3707175
3Dmark also relies on the CPU more for the final score. can give misleading resluts.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3707192
If I'm not changing the CPU at all, that shouldn't be an issue though correct?
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3707213
Actually in the very highend benchmarking the CPU power is higher Valley than in 3D Mark. With my 3way GTX980 SLI in 3D Mark ULTRA the benefit from OCing my i7 5930K from 4.4GHz to 4.7GHz were 13 points but in Valley it made a difference of almost 200 points...
https://linustechtips.com/topic/272872-benchmarking-help/#findComment-3707217
