Rampage iv has 4 pci 3.0 slots, and right now I have both my 780s in #1 and #2 slot, the first gpu is like 12 celsius higher idling than the other, does it make a performance difference if i put the second card in slot #3?
https://linustechtips.com/topic/27225-gpu-temps/
It probably gives the gpus more space to breathe meaning lower temps which allows for better overclocking.
Shorter answer: Yes?
https://linustechtips.com/topic/27225-gpu-temps/#findComment-345834
If you put it to slot 3 then slot 1 card gets more air and runs cooler.
And after that you get more performance,because of GPU boost 2.0
https://linustechtips.com/topic/27225-gpu-temps/#findComment-345838
I might be wrong here, but doesnt the rampage IV have 16x slots in numer 1 and 4 pci slots? Atleast that is what I think I can see on my rampage IV extreme. I dont know if that increses performance, but I seem to have read somewhere that a Titan would be close to saturating a 16x slot (that might have been in a gen 2 slot though..) correct me if Im wrong! ;)
But yes, like the others have said, it would probably be a good idea if you want a cooler card. :)
(Comming soon)
https://linustechtips.com/topic/27225-gpu-temps/#findComment-345892
Do i still get the full bandwidth/power or whatever to both cards? IDK how that stuff works :s  like.. one wont be x16 and one wont be x4 or whatever
https://linustechtips.com/topic/27225-gpu-temps/#findComment-345931
I'm not sure but I think when you sli, the two cards run at x8 anyway.
https://linustechtips.com/topic/27225-gpu-temps/#findComment-346060
I'm using slots 1 and 3 on my RIVE.
Intel Core i7 4930K @ 4.7GHz | Asus Rampage IV Extreme | 2 x EVGA GTX Titan SC (1254MHz) | 16GB Patriot Viper Extreme DDR3 2133MHz (4 x 4GB) | Corsair AX1200 | Silverstone Temjin TJ11 | Corsair Force 3 240GB (System) | 2 x Intel 320 160GB SSD (Dedicated Gaming Drives) | Hitachi Deskstar 1TB (Data) | MS Windows 10 Pro | EK Supreme HF/FC-Titan/Rampage IV Extreme blocks | Hardware Labs GTX 560/240 rads | Alphacool VPP-655 D5 pump | Bitspower mod kit/pump top/fittings/120mm res
https://linustechtips.com/topic/27225-gpu-temps/#findComment-346356
