yes it will be fine and you will have room for upgrade
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/271953-psu-help/#findComment-3689472
Ok thanks
no problem one time i was running a 300w system on a 750w psu and no problem just remember the 750W is a LIMIT not A TARGET
1
https://linustechtips.com/topic/271953-psu-help/#findComment-3689538
A PSU's best efficiency is at around 50% load, so a 750W will be more efficient than a 500W if your computer uses 500W
So yes a 750W PSU is a good choice :)
https://linustechtips.com/topic/271953-psu-help/#findComment-3689571
The difference is only a few % so not really worth bothering about. Plus a 750W will cost more to buy (Usually)
No... usually it is about 20%+ difference between the most and least efficient the PSU curve can be.
https://linustechtips.com/topic/271953-psu-help/#findComment-3690339
Where did you pull that wild figure from ?
A Bronze rated psu is 81% @ 20% load, 85% at 50% load and 81% at 100% for 230V
A Gold rated psu is 88%, 92% and 88% for the same loads on 230V.
Any power supply with an 80 plus rating has to be at least 80% efficient.
http://www.hardocp.com/article/2011/10/04/80_plus_irrelevant_to_you_when_buying_psu/2#.VJHmXE1yamw
https://linustechtips.com/topic/271953-psu-help/#findComment-3690609
This is basically how it is for all PSUs
https://linustechtips.com/topic/271953-psu-help/#findComment-3690653
The efficiency only starts dropping off when the load is below 20%. That goes for Bronze, Silver, Gold, Platinum and Titanium rated units. Like I said above, a Gold rated is only around 3-5% more efficient @ 50% load than a Bronze depending on the psu in question. In terms of electricity savings then you are talking pennies unless you are running the pc 24/7 365 days.
https://linustechtips.com/topic/271953-psu-help/#findComment-3690993
