Help Finding Wig
Guest Philosophy
Are you trying to look like him? That's...creepy.
I have a musician idol too, but I would never attempt to look like them.
https://linustechtips.com/topic/271744-help-finding-wig/#findComment-3686492
Who the hell is that?
https://linustechtips.com/topic/271744-help-finding-wig/#findComment-3686533
Just answer my question... I need to know and I cannot find any...
Go to a wig shop? Prop store? Photoshop?
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/271744-help-finding-wig/#findComment-3686536
I am not nearly that good at photoshop or I might, but a plus with the wig is I can take it off when I got to work so I do not get fired. I never knew there was a Wig Shop.
depending where you live there probably is one. If not go look at a prop shop. If they have one in your town.
https://linustechtips.com/topic/271744-help-finding-wig/#findComment-3686561
a close friend of mine has one
https://linustechtips.com/topic/271744-help-finding-wig/#findComment-3686595
Has a wig shop? Does he ship to the US and does he have a jack white wig?
wigs and accessories he has it in pink and blonde that work?
https://linustechtips.com/topic/271744-help-finding-wig/#findComment-3686607
lel why would you need a wig for your job?
CPU: i7 2600 @ 4.2GHz  COOLING: NZXT Kraken X31 RAM: 4x2GB Corsair XMS3 @ 1600MHz MOBO: Gigabyte Z68-UD3-XP GPU: XFX R9 280X Double Dissipation SSD #1: 120GB OCZ Vertex 2  SSD #2: 240GB Corsair Force 3 HDD #1: 1TB Seagate Barracuda 7200RPM PSU: Silverstone Strider Plus 600W CASE: NZXT H230
CPU: Intel Core 2 Quad Q9550 @ 2.83GHz COOLING: Cooler Master Eclipse RAM: 4x1GB Corsair XMS2 @ 800MHz MOBO: XFX nForce 780i 3-Way SLi GPU: 2x ASUS GTX 560 DirectCU in SLi HDD #1: 1TB Seagate Barracuda 7200RPM PSU: TBA CASE: Antec 300
https://linustechtips.com/topic/271744-help-finding-wig/#findComment-3686626
@thekeemo How do you happen to know a wig shop guy who is up at midnight? xD
he's not up right now I just sent him a message. And like I said its a close friend
https://linustechtips.com/topic/271744-help-finding-wig/#findComment-3686686
