My mouse is about 4 years old and it starting to have some problems.The biggest one is when I move my mouse very quickly from side to side in equal amounts and the mouse cursor eventually stick onto one side of the screen; when I tried to move my cursor back to the center of the screen it the cursor sticks back to the side of the monitor. Another problem I have with my mouse is disconnection, but this happens periodically and can be easily fixed by replugging the usb port. I have tried cleaning the sensor using alcohol and a Q-tip and this didn't fix the main problem. Any advice?
https://linustechtips.com/topic/271708-rat-7-mouse-problems/
Are you using windows 8?
Because I heard from people that the mouse sometimes sticks to the edge of the screen, and that its a windows 8 bug.
https://linustechtips.com/topic/271708-rat-7-mouse-problems/#findComment-3685990
Don't buy MadCatz stuff in the future? They're notoriously crap, every product of theirs.
Sadly, there's just nothing as customizable as one of those RATs.... sadness.
In all seriousness, your mouse sensor sounds effe-d up and it is time for a new mouse.
https://linustechtips.com/topic/271708-rat-7-mouse-problems/#findComment-3685991
Really? I've never had this issue.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/271708-rat-7-mouse-problems/#findComment-3686058
It doesnt seem to happen to everybody, just a couple of cases.
https://linustechtips.com/topic/271708-rat-7-mouse-problems/#findComment-3686074
I've only had the mouse disconnection problem (that only happens about once every couple of months)
The sensor itself is rather crap, mine can sometimes get stuck, sometimes it won't detect an x or y axis movement. -> it doesn't happen too often though.
That being said, I can't live without the thumb scroll so that's why I haven't chosen a different mouse.
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/271708-rat-7-mouse-problems/#findComment-3686109
I didn't buy the mouse, it was orginally from my older brother who gave it me as he bought a Razer Naga Epic. Saved me $70 on buying my own mice.
https://linustechtips.com/topic/271708-rat-7-mouse-problems/#findComment-3692592
Yes, I'm using Windows 8.1 however I never had the same problem with other opitical and laser mice.
https://linustechtips.com/topic/271708-rat-7-mouse-problems/#findComment-3692599
Found the problem, apperently the RAT 7 sensor doesn't really like my soft black mouse pad and I did some expariment using a white piece of paper on top of my mouse pad and it works really well. So far I don't have any problems with my mouse sensor yet.
https://linustechtips.com/topic/271708-rat-7-mouse-problems/#findComment-3719417
Found the problem, apperently the RAT 7 sensor doesn't really like my soft black mouse pad and I did some expariment using a white piece of paper on top of my mouse pad and it works really well. So far I don;t have any problems with my mouse sensor yet.
Ahhh I remember reading about that problem.
I got a XL corsair mouse pad and it works pretty well.
I never used to use a mouse pad with my previous mouse (logitech g9)
https://linustechtips.com/topic/271708-rat-7-mouse-problems/#findComment-3721175
