Currently I have a 7970 ghz crossfire setup but my case does get pretty toasty. I had temps going to 91c on my gpu when I was using a noctua nf p12 as a side panel exhaust but I am not sure which is the best setup for the side panel.     Intake or exhaust.
I do have a 120mm bottom intake and a 140 front intake 120mm fan in the middle of the case. 240mm top radiator and a 120mm nf p12 as a exhaust. I am currently using the corsair sp 120 performance editions as a exhaust but it sounds like a jet engine when the graphics card is under load.
But it does keep it cool (72c max gpu temp) My 2 7970ghz has the windforce cooler on it. I am not sure if using the side panel as an exhaust is as efficient as an intake. If you have any recommendations list them.
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/271076-case-fan-setup/
That's weird because I have a 280x toxic (a rebranded 7970) and my temps never go over 70 degrees and all I have is a fan on the back blowing air out of the case
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/271076-case-fan-setup/#findComment-3677755
Always have side panel as intake
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/271076-case-fan-setup/#findComment-3677756
1 7970ghz it stays nice and frosty
2 7970 and it becomes an oven.
https://linustechtips.com/topic/271076-case-fan-setup/#findComment-3677806
The thing I am worried about is the side panel fan will blow air straight on the GPUs but it is not a reference cooler it's the gigabyte one that blows the hot air to the top of the card.
https://linustechtips.com/topic/271076-case-fan-setup/#findComment-3677828
lol watercooling=more cooler
https://linustechtips.com/topic/271076-case-fan-setup/#findComment-3677844
It is suppose to supply your open air cooler GPUs with fresh air. Try it first and tell us your tempts
https://linustechtips.com/topic/271076-case-fan-setup/#findComment-3677908
