I would go with dual GTX 780, there better price for money and have the cuda cores which you can use for the video editing and 3D animation. I wouldn't recommend the dual GTX Titans because the price to performance ratio compared to the 780 is nothing.
SPECS: MOBO - INTEL DZ77GA70K EXTEME, CPU - i5 3570 @ 3.4GHz, MEMORY - CORSAIR VENGEANCE 2 x 4G, GPU - GIGABYTE HD7970 OC, HDD - WESTERN DIGITAL CAVIAR BLACK 1TB, SDD - INTEL 520 SERIES 120GB, CASE - COOLERMASTER RC-682A-KWN5, PSU - THERMALTAKE SMART 750W, KEYBOARD - RAZER BLACKWIDOW ULTIMATE 2013, MOUSE - RAZER DEATHERADDER 2013.  :D
Dual GTX780. Why are you even considering dual 7990/GTX Titan when they are double the cost? Try and find some 4GB versions if you can. 3GB should be enough for now as long as you're not applying AA, however that might not hold true for the future....especially given the texture resolution bump we are going to see once next gen consoles are released.
3x Dell U2412M |Silverstone FT03 | Maximus V Gene | 3770K @ 4.5Ghz 1.2V | SLI GTX780 | Mushkin Ridgeback 8GB 1600 CL7 | Corsair AX760
ahahahhaha dual 7990... now that's pure awesomeness......
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
780 price/performance
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
Dual 780s if you have the money then titans all the way but they are barely better then the 780s however as you do editing i think that the titans will helps much more the 780s in that area.
Listen if you care.
