Hi all,
I'm building in the NZXT H440 with an ASUS X99 Deluxe motherboard, and I'm running into some issues with the USB 3.0 Header. I can get it plugged in, but the cable is bent very sharply and puts pressure on the header, which I'd rather avoid.
post-125125-0-55512700-1418603383_thumb.
So I'm wondering if anyone has any ideas of how I could avoid this. I was thinking of getting a header extension and modding it to have a smaller plug, and perhaps more flexible cable, is that possible? Failing that I could cut into the case so the cable only has to bend 90 degrees instead of 180, but that's something I'd rather avoid.
Regards,
Kieran
https://linustechtips.com/topic/270336-usb-30-headers/
pull the cable out behind a bit more
https://linustechtips.com/topic/270336-usb-30-headers/#findComment-3668583
Hi all,
Regards,
Kieran
It's a bit pricy but as of right now only these types of extensions will remedy what your having problems with:
http://www.moddiy.com/products/USB-3.0-20%252dPin-Internal-Header-FF-Adapter-Cable-%28Low-Profile-Connector%29.html
https://linustechtips.com/topic/270336-usb-30-headers/#findComment-3668641
Yea that connector is a pain for cable management. Worse than the 24pin atx imo.
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque euismod suscipit est, non placerat turpis vestibulum sed. Phasellus et faucibus odio. Donec a nisi at purus porttitor ullamcorper auctor a nibh. Integer id neque a nisi laoreet ultrices id ac augue. Nulla facilisi. Nullam purus elit, dictum quis euismod vitae, mollis non dui. Morbi vehicula neque eu mattis bibendum. Curabitur sed odio tortor. Sed euismod mi in diam volutpat, vitae convallis ipsum mattis. Praesent eleifend faucibus pulvinar. Interdum et malesuada fames ac ante ipsum primis in faucibus. Vestibulum velit nunc, fermentum a libero a, venenatis tempus lectus.
https://linustechtips.com/topic/270336-usb-30-headers/#findComment-3668944
 Thanks that's just what I needed, at least it's free shipping to Aus
https://linustechtips.com/topic/270336-usb-30-headers/#findComment-3669541
Oh wait hold on that's one is female to female connector, you want this one which is male and female connector:
http://www.moddiy.com/products/USB-3.0-20%252dPin-Internal-Header-MF-Extension-Cable-%28Low-Profile-Connector%29.html
https://linustechtips.com/topic/270336-usb-30-headers/#findComment-3669564
I had that problem to, i just ended up moving the header to another port near the 24 pin.
Your mobo doesn't have that though, unfortunatley
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/270336-usb-30-headers/#findComment-3675455
