I just bought a samsung 840 evo 120gb Last 5days.
I installed it and Samsung Magician Software
I tested it and here's my results
Its lower than the advertised speeds. Or its low because of the space used? Its only 20GB so maybe the read is affected because there's not much to read? xD
When I checked the Firmware update it says it has the latest firmware so I don't need the update.
10422928_10204432864613472_3519210946094
Specs are on my sig
i5 4690k @ 3.5Ghz | Stock Cooler :/ | ECS Gank Machine Z87H3-A2X EXTREME | Gskill RipjawsX 8GB 1600Mhz | MSI GTX 960 100th ME 2GB | Samsung 840 Evo 120GB | 1TB WD Caviar Blue | Seasonic m12ii evo 750W | Razer Modded Phantom 410
https://linustechtips.com/topic/269907-840-evo-slow-read/
Your AHCI Mode isn't active and with what did you connect your SSD to your mobo that's it saying N/A Sata interface?
My results, just done now with the same SSD.
CPU: i7-4770K  Cooler: NZXT X60  GPU: Asus GTX 770 2GB  MB: Asus Maximus VI Hero  RAM: Corsair Vengeance 16GB 1600MHz  PSU: Be Quiet! 630 Watt  Case: NZXT H440
       Storage: 120GB Samsung 840 Evo + 1TB Seagate HDD  KeyboardCorsair K70 RGB  MouseG502 Proteus Spectrum  HeadphoneSennheiser HD598  Mic: Blue Snowball Ice
https://linustechtips.com/topic/269907-840-evo-slow-read/#findComment-3663366
I use a SATA Cable that came with my mobo, About the AHCI mode I'll configure it later
https://linustechtips.com/topic/269907-840-evo-slow-read/#findComment-3663560
do a test with AS SSD.
http://alex-is.de/PHP/fusion/downloads.php?download_id=9
P.s about switching to AHCI mode, This will not work!
Because Windows will fail to boot then.
You will need to tweak a registry entry "msahci" in the registry first.
Change the start value to "0"
https://linustechtips.com/topic/269907-840-evo-slow-read/#findComment-3663916
I can't find the AHCI boot mode in my bios :v
https://linustechtips.com/topic/269907-840-evo-slow-read/#findComment-3664392
I don't believe that you can upgrade the firmware to the fixed one through Samsung Magician, I think that you need to download the utility separately (how it was for me).
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/269907-840-evo-slow-read/#findComment-3664531
Yes, RAPID is enabled looking at the results.
is RAPID the same as RAID? please teach me how to optimize my drive :DDDD
https://linustechtips.com/topic/269907-840-evo-slow-read/#findComment-3664755
RAPID uses your RAM as cache. Instead of Windows writing to your SSD, it will write to your RAM. Way more faster than SSD. Afterwards, Samsung drivers/software will write from RAM to the SSD. It is recommended to enable RAPID on stable systems as well as battery backup systems (laptops, desktops with UPS).
The first optimization you need to do is enable AHCI. This is a must for an SSD.
https://linustechtips.com/topic/269907-840-evo-slow-read/#findComment-3664836
How did you achieve THAT kind of results? I can't even get half the speeds. Besides: That speeds are not achievable via SATA. Is it RAPID mode?
Indeed, these are my results with RAPID enabled.
https://linustechtips.com/topic/269907-840-evo-slow-read/#findComment-3664887
Look into page 24 of your manual : http://download.gigabyte.us/FileList/Manual/mb_manual_ga-970a-ds3p_e.pdf
Don't forget switching this will prevent you to boot Windows if you didn't modify Windows properly before. You need Windows to be able to boot in AHCI mode. And you are going to need AMD drivers for AHCI if not provided by Windows already.
https://linustechtips.com/topic/269907-840-evo-slow-read/#findComment-3665039
Thanks Guys! I'll enable rapid mode after I finish downloading BF4 :D
But my IOPS is still slow, is that normal?
10432117_10204437381406389_1354132306016
https://linustechtips.com/topic/269907-840-evo-slow-read/#findComment-3668403
Thanks I didn't know about rapid mode, speeds are way faster now.
Desktop: Intel 4770k - 12GB Vengeance Pro 1866Mhz RAM - Asus Maximus VI Formula Mobo - Asus Strix 970 SLI - Cooler Master V850 PSU -  Nzxt Phantom 630 Case  - 1TB WD HDD - Samsung 840 Evo 250GB SSD - Nzxt Kraken X60 - 24" Asus VG248QE 1080p Monitor - Logitech G35 Headset -  G502 Proteus Core - Logitech G710+ Keyboard - Nzxt Hue - Windows 10
https://linustechtips.com/topic/269907-840-evo-slow-read/#findComment-3668553
