Hello, this is my first post!
-Introduction
I play some games like dayz (super laggy) and battlefield 3.
My only problem is that Battlefield 3 runs at 60 frames.
You may say, "Connor, 60 frames is great!"
-My Problem
The thing is my Battlefield will run at low settings at 60 frames but if someone runs by me or I parachute our of a heli then my frames drop to like 1-6 FPS.
-My Specs
Intel i7-3740QM
16 GB RAM
Nvidia GT 650M
~185GB SSD
1600X900 Screen
-Conclusion
After the recent update my Battlefield has been preforming slowly. Can someone please tell me why and/or how to fix it.
Please no answers like this:
ALXAndy, on 16 Jun 2013 - 2:46 PM, said:snapback.png
I have a great fix.
Get a desktop.
Thanks!
-connor0095
https://linustechtips.com/topic/26873-battlefield-3-problems/
There have been problems with stuttering with the new Nvidia drivers. I don't know if there is a fix.
OS - Windows 8.1 Motherboard - ASUS M5A99FX Pro R2.0 Processor - AMD FX 8350 Black Edition RAM - 16GB 2x8 Crucial Ballistix Sport Graphics Card - Gigabyte Windforce 2 OC GTX 660 Power Supply - Corsair CX750M CPU Cooler - NZXT Kraken X60 Wireless Adapter - ASUS PCE-N15 PCI-E Adapter Fans - x3 Masscool blue LED 120mm Fans Case - Fractal Design Define R4
Monitor - Dell S2230MX 21.5-inch Keyboard - Logitech G105 Mouse - Logitech G602 Speakers - Logitech Z130 Headsets/Headphones - Tt eSports Shock, AKG K240, California Headphones Laredo Phone - iPhone 4S
https://linustechtips.com/topic/26873-battlefield-3-problems/#findComment-341166
Which one?
I currently have 314.07 and everything works perfectly.
Dell Inspiron 580 - Modified
Build log
Win 7 | GTX 760 | i5 CPU 650 @ 3.20GHz | 2x2Gb 1333MHz Hyundai + 2x2Gb 1333Mhz Crucial RAM | Seagate 1TB 7200RPM | HyperX Fury 120Gb | Corsair Builder 600M | Fractal R2 Mini
https://linustechtips.com/topic/26873-battlefield-3-problems/#findComment-341188
I have a great fix.
Get a desktop.
im working on it
Im going to get a modified version of this in about a year when i have the money. This is my wishlist on newegg. Thanks for the sarcasm. Can you be serious now?
https://linustechtips.com/topic/26873-battlefield-3-problems/#findComment-341253
im working on it
firstly with this build the cpu and motherboard are NOT compatible as the cpu is lga1150 and the motherboard is lga1155
secondly i have a laptop with lower specs then you and i was able to play bf3 at med at around 30fps so if you beef up your detail it might fix it up
 CPU: i5-6600k MOBO: ASUS Z170 Pro Gaming RAM: G.Skill 16GB 2800Mhz 15-15-15-35, GPU: Sapphire R9 290 SSD: Samsung 840 250GB HDD: Seagate Barracuda 2TB x2, Cooling: EK supremecy EVO ,EK-FC R9 290X with backplate, XSPC EX240 Crossflow & Alphacool UT60 240mm, XSPC D5 Bayres w/ Alphacool VPP655, 7/16-5/8 Compressions/Tubing, Noctua NF-F12 x4 PSU: Silverstone Strider Plus 850W Case: Nanoxia Deep Silence 1 http://valid.x86.fr/8g2m02
https://linustechtips.com/topic/26873-battlefield-3-problems/#findComment-341318
Firstly I realize that they are not compatible when the LGA 1150 version of the motherboard comes out on newegg i will change it (this just serves as notes for now)
Secondly i run it at 60 and it has lag spikes for no reason. i just tried 314.07 and it did not fix it
https://linustechtips.com/topic/26873-battlefield-3-problems/#findComment-341413
im working on it
Relax man it was a joke more than sarcasm :)
Area 51 2014. Intel 5820k@ 4.4ghz. MSI X99.16gb Quad channel ram. AMD Fury X.Asus RAIDR.OCZ ARC 480gb SSD. Velociraptor 600gb. 2tb WD.
https://linustechtips.com/topic/26873-battlefield-3-problems/#findComment-343722
i was running bf3 on med/high with no lag spikes and no problems on a gt 525m at around 30fps
https://linustechtips.com/topic/26873-battlefield-3-problems/#findComment-347688
Sounds like your framebuffer is full, how much vram does a GT650M get?
EDIT: I just tested Battlefield at 1600x900 on low and it uses 1304MB on Karkand (1900MB on ultra/1080), which isn't even a large map, so there's your problem, BF3 really needs a 2GB graphics card
Check out my Trading Card Inventory, I probably have that one card you need
Gaming PC  Corsair C70 Arctic White ▪ MSI Z77 MPower ▪ i7-3770k, Core 4.0 GHz ▪ Patriot IEM 4 x 4GB @ 2133MHz ▪ 2 x Palit GTX 670 Jetstreams in SLI, Core 1250 MHz, Mem 3150 MHz ▪ OS on 128GB Samsung 840 Pro ▪ Silverstone ST85F-P w/ Fancy Silverstone Cables
Server ▫ Fractal Design Define R4 Titanium Grey ▪ Gigabyte GA-Z68X-UD3H-B3 ▪ i5-2500 ▪ Corsair Vengeance 2 x 4GB @ 1600MHz ▪ Asus GTX 550ti ▪ OS on 120GB Samsung 840 ▪ 5.2TB Storage Space ▪ Antex HCG 900
https://linustechtips.com/topic/26873-battlefield-3-problems/#findComment-351470
Its a 2 GB card
https://linustechtips.com/topic/26873-battlefield-3-problems/#findComment-360771
Also I look at ram and CPU usage and it doesn't even use half
https://linustechtips.com/topic/26873-battlefield-3-problems/#findComment-360779
http://www.notebookcheck.net/NVIDIA-GeForce-GT-650M.71887.0.html
This article here says the GT 650M takes DDR3 for VRAM instead of DDR5 (the difference is 900MHz vs 1500MHz on laptops).
If that's the problem (mind you, I'm just spit-balling ideas), the only thing you can really do is play around with settings, namely vsync and buffering and see if that eases off the memory.
You could also install MSI afterburner and try and crank the memory freq up, but you'll likely just get crashes instead of framedrops, as laptops don't take kindly to those kind of shenanigans.
https://linustechtips.com/topic/26873-battlefield-3-problems/#findComment-362560
