What is the largest battery bank that isnt an unruley size, and can fit in a backpack easily (no bigger than like, a textbook)
https://linustechtips.com/topic/268726-largest-battery-bank/
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/268726-largest-battery-bank/#findComment-3648933
Listen if you care.
https://linustechtips.com/topic/268726-largest-battery-bank/#findComment-3648935
A car battery with a 12-5v transformer/converter, You can fit it is your backpack.. with some violence.
The biggest one i have found is a 30 000mah batterybank, This site is in swedish, I dont know what the name is for the product http://www.tradera.com/item/341069/216361886/barbart-externt-batteri-30000-mah-iphone-och-samsung
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/268726-largest-battery-bank/#findComment-3648942
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/268726-largest-battery-bank/#findComment-3648955
https://linustechtips.com/topic/268726-largest-battery-bank/#findComment-3648975
Suit yourself but I'm enjoying mine
Looking at reviews, people say they are only like 10,000 not 50,000
https://linustechtips.com/topic/268726-largest-battery-bank/#findComment-3649003
I think it goes to the 26000mAh power castle.
Also Linus reviewed it and seemed to like it.
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque euismod suscipit est, non placerat turpis vestibulum sed. Phasellus et faucibus odio. Donec a nisi at purus porttitor ullamcorper auctor a nibh. Integer id neque a nisi laoreet ultrices id ac augue. Nulla facilisi. Nullam purus elit, dictum quis euismod vitae, mollis non dui. Morbi vehicula neque eu mattis bibendum. Curabitur sed odio tortor. Sed euismod mi in diam volutpat, vitae convallis ipsum mattis. Praesent eleifend faucibus pulvinar. Interdum et malesuada fames ac ante ipsum primis in faucibus. Vestibulum velit nunc, fermentum a libero a, venenatis tempus lectus.
https://linustechtips.com/topic/268726-largest-battery-bank/#findComment-3649062
