Hi! I upgraded my cheap laptop with an 840 evo, and bumped it up to 8GB of RAM, but with only an Intel HD 4600 GPU from the i3-4000M, I am looking for something that can handle my gear and increased use. Below is what I am looking for, and the list of parts I have chosen so far. If you are familiar with my kind of use case, please critique my choice of parts. Thanks, I appreciate your help!
post-168009-0-74320200-1418289838_thumb.
Needs:
-Power all my hardware (2x 1080p monitors, 1x 1280p monitors, and a lot of USB connected peripherals)
-Able to handle my typical multitasking all at once (25+ chrome tabs, Audacity, Photoshop, Premier Pro, Da Vinci Resolve, After Effects[beginner --> Intermediate use])
-I really don't have a price limit, but I am a practical person, who doesn't get more than what I need. (my $500 laptop runs all of this already, but seek for better stability and overall performance) (Would prefer < $700)
-Clean, Value, Compact, Non-Flashy Case (if it can hold 4+ Hard drives for RAID 10, that's a plus) (Internal aesthetics are not really important)
-Relatively quiet, but I can upgrade the cpu fan and case fans later (I don't plan on overclocking at first)
-I might get more RAM later (If my use increases)
My List of Parts:
Case: NZXT CA-S340W ATX Mid Tower [$69.79] (http://www.newegg.com/Product/Product.aspx?Item=N82E16811146190)
Motherboard: OPEN BOX BIOSTAR TA970 [$50.99] (http://www.newegg.com/Product/Product.aspx?Item=N82E16813138372R&cm_re=biostar_ta970-_-13-138-372R-_-Product)
CPU: AMD FX-6300 Vishera 6-Core 3.5 GHz [$109.99] (http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286)
GPU: MSI GTX 760 2GB [$169.99] (http://www.newegg.com/Product/Product.aspx?Item=N82E16814127744)
Memory: Mushkin Enhanced Silverline 8 GB (2x 4GB) [$64.99] (http://www.newegg.com/Product/Product.aspx?Item=N82E16820226217)
Boot Drive: Samsung 840 EVO 250 GB [126.99] (http://www.newegg.com/Product/Product.aspx?Item=N82E16820147248)
Hard Drive: (I work at my university's IT department, so I get them for free)
Power Supply: Cooler Master Elite V2-550W [$49.99] (http://www.newegg.com/Product/Product.aspx?Item=N82E16817171088)
TOTAL = $642.73
Thanks Again!
https://linustechtips.com/topic/268089-first-build-help/
Looks really good, but try to bump up the mobo a bit, it's going to be worrth it
Thanks, I probably will, since this is pretty much the cheapest one. Would you mind explaining why, though? Is it a failure rate kind of thing? Are there any features you find very helpful for general computer management? Because I think I just need the basics: 4 DIM slots, gigabit LAN, USB 3.0, 6Gb/s SATA... (I guess it would be smart to get one with PCI Express 3.0)
https://linustechtips.com/topic/268089-first-build-help/#findComment-3640884
It comes to support, maybe you go installing it and Biostar didn't even bother to update and release proper drivers for let's say Windows 10, so glitches start everywhere. A good bios, good internal controllers, build quality and quality control are very important. All the low end Biostar mobos I came across were just a headache, ram incompatibility, BSoDs, audio with a lot of noise, etc . A couple more bucks not only saves you trouble, but maybe tomorrow you need to speed up your system and don't have cash, a simple overclock can solve it, but you are going to melt the board as it doesn't have a proper power delivery.
https://linustechtips.com/topic/268089-first-build-help/#findComment-3641984
