advice with my setup (h100i with noctua nf-f12 fans)
Solved by airdeano,
what kind of temps should i be seeing if anyone knows so i have an idea what to work towards to getting it sorted.
on a 1.250vCORE would be 55-65° (30° ambient) for a dual fan H100 using IBT (MAX) or OCCT (AVX)
for 60min
maybe try it with the H100 OE fans and compare temperatures. one thing about high
density fin arrays, no air-flow no cooling... if the pump was failing (only moving part in the controller)
temps would be 100°+ (no coolant flow).
fault of the part would be no pump flow or leak.. other than that installer error. since
using non-original parts, it is tougher to diagnosis.
airdeano
