water cooling
Solved by CoolaxGaming,
Ok so there are two types of liquid coolers.
AIO's (Like the h100i) (AIO means all in one)
Custom Loops (Carzy expensive doohickys)
Lets start with the h100i it falls under the aio category and has everything you need for liquid cooling in one block and radiator. There is no need for anything else. As the name says All in one means every part included into one single part.
Now Custom loops are the ones you know bout. All different parts and can cool literally everything. Much more epensive but can expand and usually better performence. The AIOS come at fixed standards, no changing anything. With the custom loops you can go overkill and even achieve overclocked 40 degress celcius max load
