Need help with network setup.
Some sort of cable would be quicker, cleaner, less prone to 'issues' etc but if totally impossible :-
Set up a wireless router as a "client" (wireless bridge) plug the xbox and desktop into that .
Note: only some routers can be used in this way check the particular one you have in mind can do this before purchasing.
You MAY be able to get an old router to work as a client by installing DD-WRT on it
http://www.cnet.com/uk/how-to/reuse-an-old-router-to-bridge-devices-to-your-wireless-network/
No idea how easy/hard this is to do, haven't tried it.
Mmm, looking about this :-
http://www.maplin.co.uk/p/tp-link-tl-wr702n-single-band-n150-wireless-travel-cable-router-n28nf
seems ideal
It only supports one device at a time but at less than £20 maybe get two, one dedicated to each connection freeing up the laptop for 'other uses'.
But really if you can use it at all, a cable connection would be so much better
Remember instaling cable need not involve drilling walls. Run the cable along the edge of a room (under carpet[edge! Please, please, please do NOT run cable under carpet in the middle of the room]/on the skirting board), under doors, along roofs, IN roof spaces: there are gazillions of methods to installing cable that doesn't involve drilling. Length of cabling is not (shouldn't be) an issue in domestic situations as cable runs can be 100 m. Patch cables (if terminating the wires is an issue) are easily availlable up to 30m (110ft)
