So right now, I can barely render anything as my 4790k reaches 90+ degrees celcius. I am using the stock cooler and am looking to get a good, affordable cooler. I've heard the 212 evo is very good value for money, but will I be able to overclock with it in the future? I have low profile RAM so heatsink to RAM clashing shouldn't be an issue (I don't think). Also, how would an H100i or water cooling solution improve temps (if it does at all)?
Thanks,
Blueprint
Intel i7 4790k / MSI Z97M / Hyper 212 Evo / MSI Twin Frozr GTX 770 / 16GB Corsair Vengeance 1600MHz / Fractal Design Arc Mini R2 / Corsair CS750M / Samsung 840 Evo 250gb SSD /  WD Blue 1TB
https://linustechtips.com/topic/267256-overclocking-with-a-hyper-212-evo/
Watercooling would, of course, be better than the 212 evo, but the Hyper 212 should be able to achieve a decent overclock
Also, i don't think it should reach 90C just rendering! (or should it?)
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
You'd be better off going with a watercooler with those temps
Sally: l Intel i5 4690k | | Corsair H55 | | Zalman z12 plus | | Hitachi 2TB HDD | | Samsung 840 Pro 128 GB | | ASRock Fatal1ty z97 Killer | | Corsair Vengeance 16 GB | | EVGA SuperNova 750 watt | | MSI 390 | | Windows 10|
Would a H100i for example give better temps? From a video I've seen it looks like the 212 was just as good, if not slightly better. (Yeah, CPU load is usually at 100% load when rendering hence the high temps.)
H100i/H110/H105 will be definitely better.
I have a H110, and it's amazing,
Go with the h110 if you can for the 140mm Fans, but if you prefer the 120mm size, go H105, IMO it looks better
Thanks,
Blueprint
I have a FX 8350 which gets a lot more hotter in general in 4790k. Now with h100i I have a .5 ghz overclock and max temp is 60 Degrees celcius. (Why didnt I go higher? The mofsets overheat)
Lets all ripperoni in pepperoni
How much OC do you want? Im at  3.5ghz (3.0 ) stock on my bloomfield which runs as hot as a fireball. The 212+ I have can hold it down to 60C max which is incredible for my chip. AIO would definitely cool better but if you are not OC'ing a lot you don't really need the AIO (Unless you are balling!)
