Hi!
I want to purchase a case. The "NZXT Phantom" the original. I currently own a computer that runs fine but I want to change Case. In my current PC I am using the "Cooler Master Seidon XL 120mm" to cool my CPU with. But i have heard that if you are using the 200mm fan slot on the side panel of the case, something like an "Corsair H80" will not fit. So my question is: Will I be able to use a 200mm fan and my "Seidon XL" at the same time? Or do i have to sacrifice one or another. Sorry for my bad English. I am not from The US, Canada or The UK.
"NZXT Phantom" (In black): http://www.ncix.com/...er-f5-94100.htm
"Seidon XL": http://www.coolermas...r/seidon-120xl/
https://linustechtips.com/topic/266805-does-it-fit/
It's simple. Don't use the 200mm fan, as they tend to be loud ;)
But i want the extra airflow over the graphic cards. I am going to run a SLI config with two 780's.
So if anyone have tried to do this or have experience with the case, help would be appreciated.
https://linustechtips.com/topic/266805-does-it-fit/#findComment-3624773
