Hi,
I've been planning my build for a while now and I've been getting advice from my irl friends, people on here, videos etc blah blah blah. People have been telling me that for my CPU cooler I'm better off using a water cooler which I think I'd agree with if I'm trying to lower temps. But then people are telling me that if I'm trying to lower my overall costs I should go with something like the NH-D14 or a be quiet! Dark Rock Pro 3 because they are still good and are a bit cheaper.
So what should I go with? A fan or liquid? I'm trying to have a very good preforming CPU cooler that is a fair price (like the H100i which I was planning to use when someone told me to use a Dark Rock Pro 3). Budget, probably around 100 USD.
Ideas?
My build:
http://pcpartpicker.com/p/WT4QBm
https://linustechtips.com/topic/266137-cpu-cooler-advice-needed/
Air and water are both good options but a cheaper air cooler will achieve the same temps as a highend watercooler so a noctua will get you the same often better temps than let's say a Corsair H100i. But if I must admit that a watercooler looks 100x better than a huge block of copper.
https://linustechtips.com/topic/266137-cpu-cooler-advice-needed/#findComment-3615673
if you can afford it defiantly go for a water cooled cpu but if you want pur silence then go for an air cooler
I think I have a tiny bit of room to be able to get one.
I'd agree, liquid cooling looks way better, but I'm going for performance right now. So if you were to recommend a Noctua, which one is a good one that will perform better than most liquid coolers?
Go with the h100i it is quiet and keeps the cpu chilly
Thanks, but you've said the opposite of what @lani100 just said (above you) as lani said that liquid is louder and lani also said that fan cooling does the same as liquid for much cheaper but not as good looking.
Phanteks ph-tc14pe is better than the nh-d14, and doesn't have ugly fan colours.
Ah yes, the colours do look much better. But I'm not really going based on the looks, mainly performance though looks does take into consideration.
Thank you all!
https://linustechtips.com/topic/266137-cpu-cooler-advice-needed/#findComment-3615709
As I stated, it does preform better than the nh-d14, by about 3 degree's with 2 fans, 4 with 3. All while looking better.
https://linustechtips.com/topic/266137-cpu-cooler-advice-needed/#findComment-3615724
Ah okay, thanks for the numbers!
Whenever I get advice from my friends you all seem to prove them wrong, which I quite like.
https://linustechtips.com/topic/266137-cpu-cooler-advice-needed/#findComment-3615760
4690K doesn't produce a shitload of heat. A Dark Rock Pro 3 (or noctua equivalent) will be just fine, and will have less of the added noisegenerators like pumps.
You'll be fine on that cooler up to 1.35V, above that is not something you'd want to run at 24/7 anyway.
I've had both the H60 and H105, yes it looks cool but those Hydro series things are garbage.
https://linustechtips.com/topic/266137-cpu-cooler-advice-needed/#findComment-3615764
Thanks for the CPU info, thought it would actually produce a lot. As for the cooler, I think I may stick with the be quiet Dark Rock Pro 3. It's not exactly ugly and I've seen quiet a few good reviews on it! And I've also heard good reviews on the Hydro series... Hmm, thanks for the info.
Go for dark rock pro 3 IMO :D
I think I'm going to agree!
https://linustechtips.com/topic/266137-cpu-cooler-advice-needed/#findComment-3615867
No it doesn't.. Dissipated heat and operating temperature are two seprate things. Even on a 4.5ghz + Overclock, the systemload is only something like 140-150W. So that's something like 110-120W for the CPU.
That's peanuts for the Dark Rock Pro 3 (think it's rated at ~250W TDP). If it overheats, it's due to the TIM and not the DRP 3.
https://linustechtips.com/topic/266137-cpu-cooler-advice-needed/#findComment-3615874
Even if you over clock, the DRP3 is enough. Also consider the performance/sound ratio, as the h100 will be a lot louder underload.
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
https://linustechtips.com/topic/266137-cpu-cooler-advice-needed/#findComment-3616132
Is this better than the be quiet! Dark Rock Pro 3?
@Luke, thoughts (as you recommended the Dark Rock Pro 3)?
One big thing to keep in mind is that the Dark Rock Pro 3 is on sale for $59.99 at the moment. Like @Majestic said the 4690K really doesn't produce a whole lot of heat, The DRP3 will cool a 4690K with no problems even with a good overclock but spending that extra money on a AIO liquid cooler for slightly better temps is of course always an option and is your choice but is also wasteful if you are looking to save money on the build like you mentioned.
When considering price/performance the Dark Rock Pro 3 at $59.99 is definitely the best choice.
http://www.newegg.com/Product/Product.aspx?Item=9SIA68V21E0640
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
https://linustechtips.com/topic/266137-cpu-cooler-advice-needed/#findComment-3616371
Awesome, I see why you'd recommend it.
Thanks again @Luke! :)
https://linustechtips.com/topic/266137-cpu-cooler-advice-needed/#findComment-3620504
Definetly get the DRP3 as at $60 it's a steal. Also the H100i has reliabilty problems
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/266137-cpu-cooler-advice-needed/#findComment-3620943
