please answer these questions?
1) How reliable are AIO liquid coolers?
2) how long do they last until they fail?
3) are they easy to maintain/fix?
4) have you guys had any problems with AIO liquid cooling units in the past?
5) is it worth upgrading to one when it am running a 5820K with a NH-D14 at gets to 60 degrees under stress testing at stock and will only be doing a 4Ghz overclock?
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
https://linustechtips.com/topic/265729-aio-water-cooling-question/
1) very reliable
2) It can vary, but its not uncommon for them to last the life of a computer
3) You don't have to do anything to them, so yes. If they fail then you RMA it (if it's under warranty), if it's not then its not worth fixing.
4) no
5) No, a high end AIO isn't significantly better than an NH-D14
PSU Tier List | CoC
Gaming Build | FreeNAS Server
1) very reliable
4) no
thanks
The only reason to gen an AIO over a cpu cooler like the d14 is for looks, and sometimes clearence. They will perform around the same but an AIO looks cleaner and doesn't have ugly brown fans.
i like the look of my d14 and i wont be adding ram anytime soon as i am just gaming.
But why are some (like the h100i) so loud?
The following reasons: noctua fans are arguably the quietest best performing fans, there is more space between thee fins on the d14 than on AIOs, AIOs need to have a pump which adds more noise, and the fans on corsair AIOs are very loud.
if you had a stock cooler id said go water but the d14 is great and super quiet as I'm sure you know already lol
i7 3770k - sandisk ssd -evga gtx 660 - kraken x61 - 16gb corsair vengeance - nzxt h440 - logitech g502 proteus core- hackintosh = badass
