Here's the build I've put together so far, it's aimed towards a single monitor at 1080p and for fps games mainly with the occasional web browsing.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£173.94 @ Aria PC)
Motherboard: Asus MAXIMUS VII RANGER ATX LGA1150 Motherboard  (£85.20 @ Aria PC)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  (£80.39 @ Aria PC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  (£280.00 @ Aria PC)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  (£88.79 @ Aria PC)
Total: £885.10
Generated by PCPartPicker 2014-12-07 16:36 GMT+0000
My budget's £900, but that's maximum. It'd be nice to go under by £15 and pick up a few nice games. So all in all, would my PSU be enough wattage for my system? I like the colour scheme of red/black.
https://linustechtips.com/topic/265621-some-final-advice/
- snap -
I really like it, good job ^^
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/265621-some-final-advice/#findComment-3609827
Shame you are only using the one supplier, as you could get a better power supply if you went with the cheapest supplier on each component. I remember from your previous thread that you only planned on using Aria or Amazon, so probably not much you can change if that is still the case.
Apart from that it looks good.
https://linustechtips.com/topic/265621-some-final-advice/#findComment-3609904
