Is there a consensus on this? I'm using MX-4, and I know there's a bigger die on these chips so the rice grain method doesn't seem like it would be the best here? Wgat about a line? Two lines? Or an X? Or finely spreading with a razor blade even? Has anyone found one method to be superior than others?
System: Ryzen 7 5800X - Gigabyte X570 Aorus Master - Noctua D15S Chromax - 32GB 3600 RAM - EVGA Black 2080Ti
https://linustechtips.com/topic/265558-thermal-paste-application-for-5820k/
Everyone has a different method.
Do something a little bigger than grain of rice, about the size of a Pea.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
as @ThatCoolBlueKidd said, the Pea method is the best, it has the smallest possibility for air bubbles.
Just do something a bit bigger, like @ThatCoolBlueKidd suggested.
LTT's unofficial Windows activation expert.
Pea size blob or X seems to be the most common recommendation from what I've been reading here and elsewhere. I suspect there's not going to be a massive difference in either.
Would be my recommendation. Basically 2 grains of rice line (what I used for my CPU), or the pea. Just be aware that the "pea" needs to be spread a bit prior to mounting or you're going to end up with too much paste in areas. Line method is generally easier on the 2011's and get's better coverage.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
There are many ways to put thermal paste on... I´ve always been a spreader. I use a strip of an old credit card. Of course I tried down the road different techniques to apply thermal compound but the spreader method is the best for my paranoid mind ;) .
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
Thanks, useful to see the pics. :)
np. I too was daunted at first. What do I do with all this space?!?!
Took a couple line trials and mounts to get the spread right but when I tried pea it was spreading too close to the vent hole, but I use really thick Prolimatech PK-3 so it wasn't that much of a concern. Ended up with line because it gave me a more consistent horizontal spread across the die. There's no harm in doing some repeated trials and cleaning it off each time to get what you want. I don't trust my sausage fingers with spreading manually :lol:
