My CPU cooler mounted horizontally is bending down. What should I do? Flip it?
https://linustechtips.com/topic/265092-cpu-cooler-bending/
How bad is it? Pics?
^ This. You could get some clear fishing line and help reduce sag like you can with a really long and heavy GPU. :)
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/265092-cpu-cooler-bending/#findComment-3603892
It's like
5-10 degrees.
Can't really do pics, don't have functioning computer atm
https://linustechtips.com/topic/265092-cpu-cooler-bending/#findComment-3603927
what cooler isn't strong enough to stay straight under its own weight?
TPC 612.
It's deff bent down.
https://linustechtips.com/topic/265092-cpu-cooler-bending/#findComment-3606147
Try tightening all mobo screws and do complete remount on cooler. They shouldn't move after you have tighten the screws. Meaning that either screws have gotten loose or the part isn't working correctly.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/265092-cpu-cooler-bending/#findComment-3608391
I mean, the actual cooler is bent, when taken out of computer
https://linustechtips.com/topic/265092-cpu-cooler-bending/#findComment-3608709
Hammer it back to shape
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/265092-cpu-cooler-bending/#findComment-3609272
