Need help finding a mechanical keyboard
I'm not to familiar with mechanical keyboards but I think I defiantly want to get one to improve upon my gaming experience.
I'm looking for a good mechanic keyboard that is responsive in gaming for games that require a lot of key pressing at once (WoW, LoL, etc).
I'm not to bothered about anything else such as how loud they are.
My price range is around £60-70 (90-110$).
cheers!
https://linustechtips.com/topic/264272-need-help-finding-a-mechanical-keyboard/
CM Quickfire.
There are many different variations of the CM Quickfire, and they can be seen on coolermasters website.
ALL ABOARD THE g710+ HYPE TRAIN
You can get it for slightly more out of your budget. But trust me, it is worth. every. cents
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
SNIP
For repeat key presses you might find certain mechanical switches do not work well for double pressing, it might be worth seeing if you can try some out in a shop and see how well you can repeat key presses
The cooler master quickfire ones look pretty good and around my price range. How good is the storm quickfire XT?
For the G710+ and K70, those seem to be retailing for quite a lot, about 30-50£ over my budget. I guess the UK layout makes them more expensive.
Trust me. The g710+ is really high quality. (I personally use it)
Before you jump into investing into a particular keyboard, consider picking up a switch tester from max keyboard. No matter how intricate, or articulate our description of how keys "feel", typing or watching videos simply won't do justice to actually pressing the switches for yourself.
Cm quickfire tk stealth is the one I own myself and it's pretty awesome built like a tank as well.
CPU: i7 5820k @4.4GHz | MoboMSI MPower X99A | RAM: 16GB DDR4 Quad Channel Corsair LP | GPU: EVGA 1080 FTW Case: Define R5 Black Window | OS: Win 10 Pro
Storage: SanDisk Ultra II 960GB 2x WD Red 4TB | PSU: EVGA 750W G2 | Display:Acer XF270HU + Dell U2515H | Cooling: Phanteks PH-TC14PE
Keyboard: Ducky One  TKL Browns | Mouse: Steel Series Rival 300 | Sound: DT990s
I find that looking at everything you want other than the switches can help narrow it down quickly. Ask yourself these questions to help narrow down your choices:
Will a 10 keyless work for me?
Does I care if its LED lit? (colors? back lit? Programmable displays?)
Do I want Macro Keys or Media Keys?
Is there a color or material I prefer?
Do I need it to come with a wrist rest?
Do I need USB ports?
Does weight or size matter to me?
After that check for switches.
Cheers
Quickfire XT is a great keyboard. What Cherry MX switch do you want?
