So earlier this week, I accidentally downloaded a virus, and it's been a huge problem since, I can't seem to get rid of whatever it is. I downloaded a video, that turned out to be some kind of virus, it was 400MB, I thought it was a video, I didn't even check before I double clicked it. Now, I've rebooted into safe mode, and run Microsoft Security Essentials, and Malware Bytes both, but it's still not gone... I don't know what else to do besides reformatting ,which I really don't want to do right now. Help!
Case: NZXT H440 | CPU: i5 4670K @ 4.5 GHz | GPU: MSI 970, Kraken G10 | Mobo: ASRock Z97 Extreme3 | Cooler: H100i | PSU: Corsair AX750 w/ Sleeved Cables | Display: 3xBenQ RL2455M | Fans: 5xNoctua NF-F12, 1xBitFenix Spectre |
https://linustechtips.com/topic/264089-serious-virusmalware-removal/
AVG and MalwareBytes. If one can't find it, the other will most likely. Usually its MalwareBytes that doesn't catch something AVG does.. Rarely it's the other way around but I've had it happen.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
Also, second question....
If I had 3 HDDs, and I had Boot HDD 1, and I downloaded the virus file on HDD 2, should I wipe both? Even if I deleted the virus from HDD2
Well first off, how do you know it's a virus? What is happening on the computer that lets you know that MBAM and MSE haven't fixed it? There may be other options before you nuke the OS from orbit.
CompTIA A+ Certified
"We are all cups, quietly and constantly being filled. The trick is knowing how to tip yourself and let the good things pour out." - Ray Bradbury
Malwarebytes seems to find a lot of viruses, but doesn't do well with rootkits.
Give this a shot, it scans pretty quickly:
http://www.bleepingcomputer.com/download/tdsskiller/
If it finds nothing, give this a try in safe mode with no other antivirus loaded:
http://www.bleepingcomputer.com/download/combofix/
