Help Needed! - GPU/Case Fan mod - 3pin GPU fan Header
I recently bought the Gigabyte 970 ITX to put into Chibi PC. its already and improvement in every way over the MSI 760 ITX that was in there. While installing it an idea struck me. Remove the fan and use a case fan too cool it instead of the method already implemented in Chibi PC http://goo.gl/O5ieFG . I have already bought the fan, a Noctua NF-F12 Industrial IP67 2000rom PWM fan, but I need a way to connect it to the GPU. The GPU uses a less standard 3 pin header to control the fan (pictured below). I need either a cable to go from that to a fan connector or just something cheap that I can cut the cable off of and wire up my self. I though I would put this out and see if anyone had seen anything anywhere as my initial searches have had no results.
-PICS-
*The pictures were grabbed from newegg because I didnt have to pull the card out of my system then.
You can just cut off the GPU fan 3pin and solder it via 3 pin into the new Nocuta fan or get an adapter such as this:
http://www.moddiy.com/products/3%252dPin-to-3%252dPin-Mini-Fan-Adapter-Cable.html
