My Desktop
CPU: i7-5820k
MB: X99 Asus Rampage V Extreme
PSU: Corsair AX1200i
GPU: Asus GTX 970 Strix OC
CASE: Corsair Obsidian 750D
RAM: Corsair Vengeance LPX 16GB DDR4 DRAM 2666MHz
Cooler: Corsair H110
I just bought this system 2 days ago and i followed Linustechtips video of the x99 overclocking guide he said 1.3V core voltage and 4.5Ghz. I tried that but my system only able to reached 4.3Ghz with the stress test software he recommended. HELP GUYS ! IM A NOOB HERE :(
https://linustechtips.com/topic/261644-overclocking-help-first-timer/
Link :
This ^
My Desktop
CPU: i7-5820k
Be sure to turn off adaptive voltage while stress testing, and set your load line calibration to around 50%. Not all chips will be able to reach that clock speed with that voltage. In this scenario you can either bump up the voltage further (just make sure your temperatures are safe), or turn down the clock.
i5-4670k @4.2GHz Sapphire Tri-X R9 290 @1135MHz 1600MHz G.Skill RipjawsX 8GB Samsung 840 EVO 120GB Samsung 850 EVO 250GB
Corsair K70 Logitech G502 Proteus Core Logitech G230 Blue Snowball SteelSeries QcK+
YouTube // Steam // Twitter // Facebook // Google+
My Desktop
CPU: i7-5820k
Although the processors come off the same assembly line there are in fact differences in performance across the same type of chip. Follow the tutorial and keep adjusting settings such as voltage as necessary; sometimes only requires 10mV to get it stable so play around but just don't overvolt it and keep a watch on your temps to decide what you are comfortable with.
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque euismod suscipit est, non placerat turpis vestibulum sed. Phasellus et faucibus odio. Donec a nisi at purus porttitor ullamcorper auctor a nibh. Integer id neque a nisi laoreet ultrices id ac augue. Nulla facilisi. Nullam purus elit, dictum quis euismod vitae, mollis non dui. Morbi vehicula neque eu mattis bibendum. Curabitur sed odio tortor. Sed euismod mi in diam volutpat, vitae convallis ipsum mattis. Praesent eleifend faucibus pulvinar. Interdum et malesuada fames ac ante ipsum primis in faucibus. Vestibulum velit nunc, fermentum a libero a, venenatis tempus lectus.
Just because he got to 4.5GHz doesnt mean you will get to 4.5GHz too.
Every CPU is different and some over clock more while others less.
You got a CPU that overclocks less, so that's just your luck.
There's nothing else you can do unless you want to buy a new CPU to try to get higher...which is not worth it at all.
Its becasue of the silicon lottery. different processors may be better or worse at overclocking
Guys thanks for your info! :) But what temperature shall i aim not to exceed while overclocking with my Corsair H110 with i7-5820k?
I'm pretty comfortable with 70C. I wouldn't really go over 80C, but your choice. But under absolutely no cirumstances should you ever get to 85-90C. If you do, turn it down until it gets to a safe temperature.
PC Specs:
    • CPU
      Intel Pentium G3258 @ 4.0GHz
    • Motherboard
      Gigabyte GA-Z97X-SLI
    • RAM
      Corsair Vengeance 16GB 4x4GB DDR3 @ 1333MHz
    • GPU
      EVGA GeForce GTX 760 Superclocked ACX
    • Case
      Corsair Graphite 230T Red Windowed
    • Storage
      Western Digital Caviar Blue 500GB 7200RPM
    • PSU
      Antec HCG-620M
    • Display(s)
      Dell S2409W 1920x1080, HP vs19 1280x1024
    • Cooling
      Stock Coolers
    • Keyboard
      Microsoft Natural Ergonomic Keyboard 4000
    • Mouse
      Microsoft Arc Touch Mouse - Limited Edition Artist Series - Oh Joy
    • Sound
      Altec Lansing FX4021
    • Operating System
      Windows 10 Technical Preview
