Well I just installed windows 8 pro to my new pc and installed all the drivers for my mobo etc but a few centimetres of the screen on each side is cut off and for 1080p it seems pretty fuzzy. I'm using HDMI and i have it connected to an EVGA 980 superclocked video card. I have tried to set my own res but that only made the issue worse and if I go any lower than 1080p (on the windows adjust resolution app) I get about an inch of black all around the screen.
 CPU Intel Core i7-4790K  | Motherboard Asus Sabertooth z97 Mark 1 | RAM Corsair Dominator Platinum 16gb 1866mhz | GPU EVGA GeForce GTX 980 w/ ACX 2.0 | Case Fractal Design Define R4 w/Window | Storage Western Digital BLACK SERIES 3TB 3.5" 7200RPM + Samsung 840 EVO 250GB |  PSU Corsiar RM750 | Display(s) Some Acer Things | Cooling Corsair H100i + 5x Noctua NF-F12 industrial 120mm fans(they are freaking load) | Keyboard Corsair Vengeance K95 |  Mouse Logitech G502 | Sound Audio-Technica AD900x + 02+ODAC +AT2020 | OS Microsoft Windows 8.1 Pro
https://linustechtips.com/topic/261447-help/
Have you tried it with a different type of cable? (Like DVI or DisplayPort).
(Off topic: Don't forget to follow your topics, with the button in the top right corner)
https://linustechtips.com/topic/261447-help/#findComment-3561400
It's overscanning or underscanning, because it think's it's a TV due to use of HDMI.
See one of my earlier posts to change these settings:
http://linustechtips.com/main/topic/260029-monitor-not-displaying-fullscreenfull-resolution-with-hdmi-cable/?p=3546322
https://linustechtips.com/topic/261447-help/#findComment-3561402
Set safezones in your GPU driver
(Follow the link posted above)
https://linustechtips.com/topic/261447-help/#findComment-3561413
Yeah, little to no improvement.
https://linustechtips.com/topic/261447-help/#findComment-3561427
I don't have the "size" tab but I just switched top an older monitor and that fixed it but thank you all for you help  :D
https://linustechtips.com/topic/261447-help/#findComment-3561462
