Only thing I can see is that the RAM is high speed, you can save a few bucks with lower speed RAM.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/261321-first-pc-help/#findComment-3560067
If this is for gaming, I'd take out 8 gigs of that ram, and just use the other 8
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/261321-first-pc-help/#findComment-3560071
In most cases 16 gb of ram is more than what most people use. That would save you about 80 pounds with 8 gb and go with a lower speed ram like 1866. Then you can go with a 280x
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/261321-first-pc-help/#findComment-3560072
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (£244.94 @ Aria PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£23.38 @ CCL Computers)
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard  (£84.99 @ Amazon UK)
Memory: Kingston Fury Black Series 16GB (2 x 8GB) DDR3-1866 Memory  (£117.74 @ More Computers)
Video Card: Asus GeForce GTX 760 2GB DirectCU II Video Card  (£158.40 @ Aria PC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  (£72.35 @ Aria PC)
Wireless Network Adapter: Asus PCE-N53 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  (£22.99 @ Amazon UK)
Case Fan: Corsair Air Series AF120 White 52.2 CFM 120mm  Fan  (£7.98 @ Amazon UK)
Total: £933.42
Generated by PCPartPicker 2014-12-01 03:26 GMT+0000
Going with a slower speed ram and changing over to air cooling instead of liquid and removing two of the 4 extra case fans which would shouldnt need that many starting out will get you an i7-4790k which is way better for video editing/rendering and only be a $8 over your original budget. I believe for what your wanting to do with this pc you would be much happier with the better processor. Then the extra fans and liquid cooler you could always upgrade to at a later point since they are cheap vs upgrading your processor later on.
https://linustechtips.com/topic/261321-first-pc-help/#findComment-3560167
