this isnt urgent.
yes, i still use vga because i have an old monitor. but why doesn't it work with my motherboard?
if i plug it into my 260x it works like a charm, but if i plug it into my mobo,no signal!
why is it there?
because your using a dedicated video card to show the display out. the onboard VGA header is for people that aren't running a video card.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/261147-vga-connecter-help/#findComment-3558110
oooh,its for igpu's and such.
that clears a lot of things up!
thanks!
You're probably going to need something like DVI to VGA, which really is not that expensive.
BUT!
Only if that is a DVI port which can use analog signal too.
(I'm not sure which can and which can't). Otherwise you're going to do some DisplayPort to VGA stuff
https://linustechtips.com/topic/261147-vga-connecter-help/#findComment-3558204
