Best CPU for first build?
Solved by Aniallation,
I have a quick question. Is the Pentium even worth getting if you're not planning to overclock? I do eventually want to upgrade to an i5 or better, so it sounds like something good to hold me until then.
No. It's pretty much a pointless CPU to get if you're not planning to overclock, and it's not a good choice even if you do overclock it. Get an i3.
Also, use the quote button to reply to people.
