Hi everyone,
I have an extra Adata SX900 120Gb SSD. I want to know what you guys think about these two options.
1) Put it in RAID 0 with my Samsung 840 EVO 120Gb SSD.
I don't know what kind of performance I will get from putting these two together, any enlightenment would be great.
Adata specs: http://www.anandtech.com/show/5710/the-adata-xpg-sx900-128gb-review-maximizing-sandforce-capacity
Samsung specs: http://www.anandtech.com/show/7173/samsung-ssd-840-evo-review-120gb-250gb-500gb-750gb-1tb-models-tested
2) Clone my new laptop hard drive (750 Gb HDD) and replace it.
My laptop isn't really bothering me that much, but it is new and I know the SSD will stay fast for longer.
Any thoughts and opinions would be great.
Thanks
https://linustechtips.com/topic/259184-help-with-ssd/
Don't do raid, the small speed boost is barely noticeable, and will definitely not be worth the issues that come with raid.
https://linustechtips.com/topic/259184-help-with-ssd/#findComment-3538524
You will wreck your EVO if you try that.
Sir William of Orange: Corsair 230T - Rebel Orange, 4690K, GA-97X SOC, 16gb Dom Plats 1866C9,  2 MX100 256gb, Seagate 2tb Desktop, EVGA Supernova 750-G2, Be Quiet! Dark Rock 3, DK 9008 keyboard, Pioneer BR drive. Yeah, on board graphics - deal with it!
https://linustechtips.com/topic/259184-help-with-ssd/#findComment-3538715
As someone with 6 raid 0 SSDs I dont think you should do it.
Why should someone not use a raid 0 set up? I wouldn't recommend it with the drives the OP is using but with something more reliable like Intel SSD's.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
https://linustechtips.com/topic/259184-help-with-ssd/#findComment-3541191
Reliability isn't the main issue. Also if you're using Intel's built in raid your boot times will actually be slower which is the opposite of what everyone thinks. It's just a pain to deal with.
https://linustechtips.com/topic/259184-help-with-ssd/#findComment-3543477
