Sony vegas GPU acceleration - Which GPU ?
if you want a cheaper option, go the 750ti
CPU Intel I7-4700MQ @2.4 ghz, turbos to 3.4
Motherboard  whatever toshiba put in the thing
RAM 8GB 1600mhz
GPU  Nvidia Geforce GT 740M
Storage 750Gb 5400rpm
Cooling  Crappy laptop fan
Operating System  windows 8 64 bit
01101001 01100110 00100000 01111001 01101111 01110101 00100000 01101000 01100001 01100100 00100000 01110100 01101111 00100000 01000111 01101111 01101111 01100111 01101100 01100101 00100000 01110100 01101000 01101001 01110011 00100000 01101001 00100000 01100100 01101111 01101110 00100111 01110100 00100000 01100010 01101100 01100001 01101101 01100101 00100000 01111001 01101111 01110101
actually looking for a better alternative, How is nvidia doing on the open CL front ? is it far behind AMD ? the results of benchmark are very finnicky where amd beats out nvidia 50% of the time
Ok, AFAIK AMD is destroying nvidia in open CL
RAM 8GB 1600mhz
Vegas doesn't support CUDA if I can recall. Adobe's software does.
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
GPU acceleration in sony vegas with gaming cards is kind of pointless.
Actually it does ! I might make a video and post it here, with basic effects on my 4930k only i get 2-3fps on 4k footage, with the 290x activated, it jumps to 15-20fps !
