Not detecting HDDs
By
bossman111
in Troubleshooting
in Troubleshooting
Solved by Techpumpkin_WD,
Hello,
You can test if a different OS than Windows can detect the drives and maybe test with a different PC. Also try to upgrade your motherboard SATA controller drivers. Another thing that might help is to disable Fast Startup if you are using Windows 8 or 8.1.
Hope you get it sorted soon.
ken43 ·
Posted in Troubleshooting3 -
5
thedood2k ·
Posted in Power Supplies3 -
1
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
Xx-albinos-xX ·
Posted in Troubleshooting10
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
