I have a budget of about $2000. This will be for video editing in Premiere Pro and compositing in After Effects. I will also do light gaming rarely on this computer. I need a good mechanical keyboard and mouse, but I have plenty of monitors. I also need an OS for the build. I want to buy most of the components during black friday and cyber monday when there cheaper.
Thanks!
-James
https://linustechtips.com/topic/257963-2000-workstation-build/
Thanks!
-James
Best option would be to buy 8.1 and get the free upgrade to 10 when it comes out next year.
In Stock
Limit 5
In Stock
  • $314.99
In Stock
  • $129.99
  • $125.99
  • Save: 3.08%
In Stock
Limit 2
  • $349.99
  • $299.99
  • Save: 14.29%
In Stock
Limit 15
  • $99.99
  • $64.99
  • Save: 35.00%
In Stock
Limit 3
  • $279.99
  • $229.99
  • Save: 17.86%
In Stock
1
In Stock
  • $0.99
  • $0.00
  • Save: 100.00%
1
In Stock
  • $0.99
  • $0.00
  • Save: 100.00%
Subtotal: $1,555.93
Great option for both gaming and heavy video editing, for gpu you could go with a 970 which does have slightly better preformance.
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
https://linustechtips.com/topic/257963-2000-workstation-build/#findComment-3526019
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor  ($544.98 @ SuperBiiz)
Motherboard: MSI X99S SLI Plus ATX LGA2011-3 Motherboard  ($217.99 @ SuperBiiz)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($98.98 @ SuperBiiz)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($334.99 @ SuperBiiz)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($89.99 @ Newegg)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.98 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($86.43 @ SuperBiiz)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($109.94 @ NCIX US)
Mouse: Logitech G402 Wired Optical Mouse  ($51.97 @ Amazon)
Total: $2010.95
Generated by PCPartPicker 2014-11-26 12:29 EST-0500
"an obvious supporter of privacy"
https://linustechtips.com/topic/257963-2000-workstation-build/#findComment-3526026
what if i wanted to go with a lower end cpu like the 5820k. I was also wondering if it would be better to go with a quadro card, rather than the geforce card.
quadro would be definately better for video editing but not so much for gaming
https://linustechtips.com/topic/257963-2000-workstation-build/#findComment-3526080
I recomend you the above an get a motherboard with more pcie lines... becausee intel now has a discount in intel phil co processor which i beleive you will get the most performance out out it
and with a coroperations of a xeon processor and a beast gpu !!!
OUFFFFFFF, to much POWER!!!!
https://linustechtips.com/topic/257963-2000-workstation-build/#findComment-3526161
But right now the exon phi is not in my budget, but i may get one in the future. So, what would be the best quadro card for my budget?
Sure a quadro is good , the xeon phil is for about 175$ so i tink you might be able to fit it in you budget,
Also you have the desision of a firepro gpu
https://linustechtips.com/topic/257963-2000-workstation-build/#findComment-3526297
Could you give me the link to this exon phi.
Also I would want to go with a quadro rather than a firepro because the quadros are certified for both after effects and premiere pro.
I have herd alot about exon phi's, but what exactly are they, and how are they going to help my editing and rendering?
https://linustechtips.com/topic/257963-2000-workstation-build/#findComment-3526344
http://linustechtips.com/main/topic/255874-world-wide-intel%C2%AE-xeon-phi%E2%84%A2-coprocessor-31s1p-200/#entry3502352
heres the link
so bassicly a xeon phil is a co-processor which give more cores to render , like the quadro cards which have cuda cores the phil cas cores also. Imagine as you have a gpu with cores and now with the intel phil you have more cores which will make your end result faster... i will try to fit it in my budget if i were you .... but of you can ' t is ok...
read though the link :)
Hope i help you
https://linustechtips.com/topic/257963-2000-workstation-build/#findComment-3526396
Yeah why not?
On the website its says:
  • Passively cooled card (for servers not for use in workstations)
I am not a 100 % sure if you can use it in your workstation
Maybe ask in the gpu department ... you will get more decent results
https://linustechtips.com/topic/257963-2000-workstation-build/#findComment-3526522
