I put together two build but cant decide which one is better.Please let me know your thoughts and opinions and plz leave some suggestions.Thx guys!!
Bal:1,700
Build 1
Cpu:Intel Core i5-4690k($210)
MoBo:Msi z87-G45 Gaming ATX($124)
Ram:G.Skill RipJaws X Series 16gb(2x8) ($135)
SSD:Samsung 840 EVO 250gb($120)
HDD:Western Digital Caviar Blue 1tb($49)
GPU:Evga geforce gtx 980 4gb($595)
Case:Phanteks Enthoo Pro($100)
PSU:Corsair CX 750w 80+ Bronze($70)
Cheap Optical Drive($17)
OS:Windows 8($87)
Monitor:Asus VS247H-P
Cheap Wirless Network Adapter($23)
KeyBoard/Mouse:Cooler Master CM Storm($30)
Cheap Speakers($9)
Build 2
CPU:Intel Core i7-4790k($300)
MoBo:Asus Maximus VII Hero ATX($195)
Ram:Kingston Fury Black 16gb:(2x8) ($155)
GPU:Gigabyte Geforce Gtx 970($335)
Case:Phanteks Enthoo Pro full tower case ($100)
PSU:Evga 750w b2 80+ Bronze ($70)
Blue Ray Optical Drive ($40)
OS:Windows 8($87)
Cheap Wireless Network Adapter ($24)
Keyboard/Mouse:Cooler Master CM Storm($30)
HeadPhones:LogiTech G230 ($35)
Cheap Speakers ($9)
Thanks So much Guys!!!!! And will i need any extra cables besides the things i have here?And how many fps will i get on games on ultra settings?Thx alot!
https://linustechtips.com/topic/257569-wich-build-is-better/
Bal:1,700
Build 1
OS:Windows 8($87)
Cheap Speakers($9)
Build 2
OS:Windows 8($87)
Cheap Speakers ($9)
Why not just save money and get an i5+GTX 970? You'll still get more than 60FPS on Ultra on damn near any game.
https://linustechtips.com/topic/257569-wich-build-is-better/#findComment-3522127
I'd say save money and get the i5 + 970 and put a little more money in to a better PSU.  Could also swap out the SSD for another one, a little cheaper the MX100 by Crucial, it's equivalent performance, if not a little better and uses MLC nand, which some do enjoy over TLC.  All in all looks solid ^^  Eventual upgrades to it when you have money could be to a Zowie mouse, CM-storm TK keyboard(mechanical), and eventually some HyperX Cloud's for the headset, but overall solid beginning ^^
https://linustechtips.com/topic/257569-wich-build-is-better/#findComment-3522155
Why not leave the 980 for the possible 120-144hz or 1440p monitor ?
My modded Air 540 build
https://linustechtips.com/topic/257569-wich-build-is-better/#findComment-3522174
That is a true option as well.  If he is only going for 1080p, 970, but if he does decide to go to over 60hz on 1080 or to 1440p - 970 sli is good, or a single 980 is perfect as well.  It's all based on budget, I suppose.
https://linustechtips.com/topic/257569-wich-build-is-better/#findComment-3522201
Yeah, you did summ it pretty well :)
https://linustechtips.com/topic/257569-wich-build-is-better/#findComment-3522220
i like build one the most.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/257569-wich-build-is-better/#findComment-3522513
get build # 1 and switch the gtx 980 in to a 970 or a r9 290, a 970 / r9 290 is plenty for today's games. Also you WILL have compatibility issue with the new intel refresh series and a z87 motherboard. Get a z97 board. Also the 290 is 2 times cheaper.
https://linustechtips.com/topic/257569-wich-build-is-better/#findComment-3522594
Im going to be using the one included with the cpu since i dont plan on overclocking
why get a K-series CPU in the first place if you are not overclocking? if u want to get a K, use a Hyper 212 Evo: its cooler, quieter, allows for decent overclocks and is pretty darn cheap.
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
https://linustechtips.com/topic/257569-wich-build-is-better/#findComment-3526911
